Greetings (No First Name Supplied),
brainwav wrote:Hi, I saw an add for a 10Mhz oscilloscope and was wondering if that is good for testing uC signals and basically debugging the circuitry? I mainly do little robots and use PICs or AVR's. Is 10Mhz too slow?
If you currently don't have a 'scope, then anything
would be better (assuming it works...)
A more important question is does it offer dual
channels (traces)? Most scope work is comparing two
signals in time, so to see both on the same screen is
necessary.
The bandwidth is less of a concern unless you are
attempting work where timing is critical. There are
easy work arounds to capture fast "glitches" if that
is thought to be the problem with your circuit, a
slow scope will slow everything down, and relative
timing of events will be faithfully maintained.
Second, make sure the scope has a trigger circuit,
without it the waveforms will be hard (or impossible)
to stabilize on the screen.
There are so many good scopes with 60MHz (or
more) that selling a ten meg scope seems silly.
Lastly, if you're interested in documenting the
scope's data consider a digital or PC based scope.
If you're more interested in investigating circuits
the budget will go further with a used analogue
scope from twenty years ago. Stay away from
tube scopes (they cost a lot to run, drift, and need
more frequent maintenance). Many analogue
scopes on the leading edge (during the Reagan
era) used exotic parts that are no longer
available. Scopes with dim CRTs may be useful
for hobby service, but will eventually go dark.
Comments Welcome!
