- Mon Mar 07, 2005 7:15 pm
#3390
I'm interested in a Lassen iQ module to play with, but not sure what antenna to buy. The tiny active antenna seems best (will fit easily in any device I build later) but I'm not sure how fragile it is (no housing) and what sort of reception it will get. Will it get reception indoors? Near a window? How does it compare to ther other antenna options? Could you maybe post a comparision guide like you have for PIC programemrs?
Also, does the USB evaluation board hold the module in just with the socket connector on the module? Which would mean it's easy to remove and use somewhere else (not glued or soldered to board) but it also could get disconencted if moved around much, correct? How easily does it disconnect? If you turned the eval board upside down, would it fall off?
I use Mac OS X, so hopefully I can get the evaluation board to spit out NMEA to the USB "serial port" so I can read the data. I plan to also hook up this module to a PIC later on.
