- Thu Mar 03, 2005 7:18 pm
#3353
Nathan,
I know its been a long time since we last spoke. We met in Seattle at the robothon. I am from tenneessee technological university. I've recently resumed work on creating an ad-hoc wireless network using the SMiRF transcievers. I just thought that you would be interested in an update. I have made some major changes to the firmware and currently have a fairly well working version. Currently there I am working on a code library required to use more than two of the devices in the system. Essentially I have modeled my methodology after TCP/IP. The SMiRF is simply the data-link layer and physical layer. Although in my model they are called something else. The code library I am working on provides the functionality of the network layer, transmission layer, etc... Of course the eventual goal is to integrate this code into the firmware and allow for a menuing system to set up IP addresses and such. This would leave only the application layer to the software designer and the application could be written in another language or compiler.
I should have a working version within the next couple of weeks. At least I better have a working version because my thesis is due in four weeks. So I need this code to be finished or else I'm in a lot of trouble. At least for my thesis I only need to develop a version using the external code library. I want to find someone interested in assisting me in continuing the developement of this code. Otherwise I may not get back to it until I start my dissertation. It will probably lead to a journal publication. Which is interesting.
So I guess the big questions I have are first of all do you know anyone interested in co-developing this code with me. Second is I want a license for the cc5x compiler. But its kind of expensive. You wouldn't happen to be able to pull any strings would you. I dont mind paying for it but I am just a poor college student. If you can't thats cool I understand. But if you know someone interested in working with me let me know.
Joe Ernest
Electrical Engineer
iLight Technologies, Inc.
1093 Volunteer Dr.
Cookeville, TN 38501
Electrical Engineer
1093 Volunteer Dr.
