- Sat Oct 20, 2007 8:53 am
#36761
I ordered the Bluesmirf and USB bluetooth dongle a few days ago here, I'm using it to interface to a SSC-32 from lynxmotion.
My SSC-32 works fine plugged in directly via serial cable.
However, I've setup the Bluesmirf according to the instructions in Jim's (lynxmotion) tutorial, and as soon as I go to select the allocated com port in Lynxterm (SEQ as well) to set baud rates, it BSOD's my PC with an irql not less or equal etc. I've tried this on 3 PCs, same result on every one. .
The only difference in setting this up from Jim's instructions, is that I'm using the supplied software that came with the usb dongle (from sparkfun, and its mentioned as the new software used) instead of Bluesoleil, and I cant get bluesoleil to find my dongle anyway.
Any ideas on this or is my Bluesmirf bad?
