- Sat Feb 12, 2005 3:12 pm
#3032
I have a question regarding Rx and Tx pins of SMIRF 2.0
From my understanding, Tx is output pin and Rx is input pin.
If there is no input, it should be High (stop bit)...
so basically if I just connected SMIRF to power and ground only, Rx pin should be high as there is no input.
However, I am getting Rx pin as low... which is Start Bit.... but there is no signal received........ (the base unit is not even started)
