- Wed Jul 25, 2007 5:03 pm
#32954
Hi to all.
I changed my tx circuit and, now, I use a pic 16f88.
It's connected as :
Can somebody tell me if the init code for tx and rx (TX_Mode routine and
RX_Mode routine) are correct? And the SPI_RW routine?
The TX_mode and the RX_Mode are based on the firmware from Nordic.
Please, help...
Thanks to all for your patience.
Sergio
It's connected as :
The circuit of the Rx is based on pic 16f877 as:
// Control and SPI Pin defines //////////////////////////////////////
#byte PORTB = 0x06
#bit CE = PORTB.6 // output Chip enable to nRF24L01 CE
#bit CSN = PORTB.2 // output Chip Select to nRF24L01 CSN
#bit SCK = PORTB.5 // serial clock output to nRF24L01 SCK
#bit MOSI = PORTB.3 // serial data out to nRF24L01 MOSI
#bit MISO = PORTB.4 // serial data in from nRF24L01 MISO
#bit IRQ = PORTB.0 // input valid TX/RX from nRF24L01 IRQ
And this is the spi.c include file:
#bit CE = PORTC.1 // output Chip enable to nRF24L01 CE
#bit CSN = PORTC.2 // output Chip Select to nRF24L01 CSN
#bit SCK = PORTC.3 // serial clock output to nRF24L01 SCK
#bit MOSI = PORTC.5 // serial data out to nRF24L01 MOSI
#bit MISO = PORTC.4 // serial data in from nRF24L01 MISO
#bit IRQ = PORTC.0 // input valid TX/RX from nRF24L01 IRQ
The tx start code is:
// Function: SPI_RW
// Description:
// Writes one byte to nRF24L01, and return the byte read
// from nRF24L01 during write, according to SPI protocol
int SPI_RW (int byte)
int bit_ctr, byte2;
byte2 = 0;
#ifndef _TX
printf ("Byte: %X - ", byte);
#endif
for (bit_ctr=0; bit_ctr<8; bit_ctr++)
byte2 <<= 1;
MOSI = (byte & 0x80);
SCK = 1;
if (MISO) bit_set(byte2,0);
SCK = 0;
byte = (byte<<1);
#ifndef _TX
printf("Status: %X\n\r", byte2);
#endif
return (byte2);
// Function: SPI_Read
// Description:
// Read one byte from nRF24L01 register, 'reg'
int SPI_Read(char reg)
int reg_val;
CSN = 0;
SPI_RW(reg);
reg_val = SPI_RW(0);
CSN = 1;
return (reg_val);
// Function: SPI_RW_Reg
// Description:
// Writes value 'value' to register 'reg'
int SPI_RW_Reg (char reg, char value)
int status;
CSN = 0;
status = SPI_RW(reg);
SPI_RW(value);
CSN =1;
return (status);
// Function: SPI_Write_Buf
// Description:
// Writes contents of buffer '*pBuf' to nRF24L01
// Typically used to write TX payload, Rx/Tx address
int SPI_Write_Buf(char reg, char *pbuf, char bytes)
int status, byte_ctr;
CSN = 0;
for (byte_ctr=0; byte_ctr<bytes; byte_ctr++)
SPI_RW(*pbuf++);
CSN = 1;
return (status);
// Function: SPI_Read_Buf
// Description:
// Reads 'bytes' #of bytes from register 'reg'
// Typically used to read RX payload, Rx/Tx address
int SPI_Read_Buf(char reg, char *pBuf, char bytes)
char status, byte_ctr;
CSN = 0; // Set CSN low, init SPI tranaction
status = SPI_RW(reg); // Select register to write to and read status byte
for(byte_ctr=0;byte_ctr<bytes;byte_ctr++)
pBuf[byte_ctr] = SPI_RW(0); // Perform SPI_RW to read byte from nRF24L01
CSN = 1; // Set CSN high again
return(status); // return nRF24L01 status byte
// Function: TX_Mode
void TX_Mode(void)
// Setup RX/TX address width
SPI_RW_Reg(WRITE_REG + SETUP_AW, (TX_AW-2));
// Writes TX_Address to nRF24L01
SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_LENGTH);
// RX_Addr0 same as TX_Adr for Auto.Ack
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_LENGTH);
// Just in case, flush TX FIFO
SPI_RW_Reg(FLUSH_TX,0);
// and RX FIFO
SPI_RW_Reg(FLUSH_RX,0);
// read status & clear IRQ flag's
SPI_RW_Reg(WRITE_REG + STATUS, 0x70);
// Writes data to TX payload
SPI_Write_Buf(WR_TX_PLOAD, TX_PAYLOAD, TX_PLOAD_WIDTH);
// Enable Auto.Ack:Pipe0
SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);
// Enable Pipe0
SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);
// 500µs + 86µs, 10 retrans
SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x1a);
// Select RF channel 40
SPI_RW_Reg(WRITE_REG + RF_CH, 40);
// TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR
SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x0f);
// Set PWR_UP bit, enable CRC(2 bytes) & Prim:TX. MAX_RT & TX_DS enabled
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);
// Add a delay of 1.5ms before toggling CE high if the device was
// in power down mode.
// This device is now ready to transmit one packet of 16 bytes
// payload to a RX device at address '3443101001', with auto
// acknowledgment, retransmit count of 10(retransmit delay of
// 500µs+86µs)RF channel 40, datarate = 2Mbps with TX power = 0dBm.
// Function: RX_Mode
void RX_Mode(void)
// Use the same address on the RX device as the TX device
// and RX FIFO
// Enable pipe0
// 250µs+86µs, 10 retrans...
SPI_RW_Reg(WRITE_REG + SETUP_RETR,0x0a);
// Select same RX payload width as TX Payload width
SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH);
// Set PWR_UP bit, enable CRC(2 bytes) & Prim:RX. RX_DR enabled
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);
// Function: PWR_DWN_Mode
// Power down the nrf24l01 module.
void PWR_DWN_Mode(void)
SPI_RW_Reg(WRITE_REG + CONFIG, 0x00);// Power down...
And the Rx start code is: CE = 0;
TX_Mode();
delay_ms (2);// Add a delay of 2ms before setting CE high if the
// device was in power down mode.
CE = 1; // Set CE pin high to enable TX device
delay_ms(5); // Wait till all TX done (could pool register or use int pin...).
CE = 0; // Finish TX.
//PWR_DWN_Mode();// Sleep, baby...
delay_ms(2000);
In the Rx part, I receive this stuff when init (in hiperteminal):
CE = 0;
RX_Mode();
// This device is now ready to receive one packet of 16 bytes
// payload from a TX device sending to address '3443101001',
// with auto acknowledgment, retransmit count of 10, RF channel
// 40 and datarate = 2Mbps.
CE = 1; // Set CE pin high to enable RX device
while(1)
while(IRQ);
printf("Received data...\n\r");
// Flush RX FIFO
// Read status & clear IRQ flag's
I still can't get it to work ! I'm getting old, very old...Byte: 23 - Status: 0E
Byte: 03 - Status: 08
Byte: 2A - Status: 0E
Byte: 34 - Status: 08
Byte: 43 - Status: 08
Byte: 10 - Status: 08
Byte: 01 - Status: 08
Byte: E1 - Status: 0E
Byte: 00 - Status: 08
Byte: E2 - Status: 0E
Byte: 27 - Status: 0E
Byte: 70 - Status: 08
Byte: 21 - Status: 0E
Byte: 22 - Status: 0E
Byte: 24 - Status: 0E
Byte: 0A - Status: 08
Byte: 25 - Status: 0E
Byte: 28 - Status: 08
Byte: 31 - Status: 0E
Byte: 26 - Status: 0E
Byte: 0F - Status: 08
Byte: 20 - Status: 0E
Please, help...
Sergio
