- Tue May 22, 2007 3:54 am
#30326
You could probably achieve 6 feet with a 50 ohm resistor in place of the antenna! I have a client app which needs range around that. I originally used the chips, but range on the lowest power with receiver in most insensitive mode was about 12 feet. I removed one of the chips, and attached a 3/4" piece of wire. That did it! Attach a 1" piece of straight wire to both boards. That will give you plenty of range, or do a PC trace of about that length with no ground plane beneath. These little chips get good range without the fancy chip antennas. For a commercial app, you need to pay attention to spectral response and need a resonant antenna length. For a home project, there is no such constraint.
Ron
