- Tue Dec 26, 2006 10:11 pm
#24202
I would like to associate some timing data with the binary data values received from the WiTilt v2.5 devices for post processing purposes.
Along this line, does anybody have details on the WiTilt v2.5 A/D polling timing specifications. More specifically, assuming the device is setup to sample all 3-axis, with binary data ouput and at its' maximum sampling rate of 610Hz, what is the time between samples of X, Y, Z axis? Can I assume this is fairly periodic by design? Is it as straightforward as (1/610Hz)/3 to get the time between samples?
Thanks in advance for your help,
Fritz
Fritz
