Unexpected bytes received by RN-131
Posted: Mon Apr 02, 2018 2:28 am
I'm trying to test a small HTTP server based on WIFLY module RN131 and an AVR micro in my wifi home local network.
I know that this device is designed to work as a client, however in my case I find a strange behaviour that i cannot explain and don't know if related to the design of this module or if I am missing something in module setup.
Here is my test:
After power on the server correctly joins my home network and is listening on port 2000. His IP address is 192.168.1.2.
From a browser (firefox on PC or on Android device connected to my wifi) i fill the following URL line: http://192.168.1.2:2000/LEDON.
The browser sends the following HTTP requests:
GET /LEDON HTTP/1.1
Host: 192.168.1.2:2000
User-Agent: Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:59.0) Gecko/20100101 Firefox/59.0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-US,en;q=0.5
Accept-Encoding: gzip, deflate
Connection: keep-alive
Upgrade-Insecure-Requests: 1
Pragma: no-cache
Cache-Control: no-cache
This request is correctly received from the RN131 serial port, and is processed by the AVR program (led is turned on).
After this, the server sends back the following HTTP response to the RN131 serial port:
HTTP/1.1 200 OK
Content-Length: 49
Content-Type: text/html; charset=utf-8
Connection: Closed
<blank line>
<html><body><h1>Led turned on!</h1></body></html>
<blank line>
Looking at the data received at the browser side, i see many bytes of garbage (mainly 0xFF's - ASCII ÿ ) around the HTTP response sent by the server like this:
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿHTTP/1.1 200 OK
Content-Length: 49
Connection: Closed
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
This doesn't allow the browser to format the HTML message in the <body...</body>.
Has someone an idea why these bytes generated by the RN-131 serial port?
Thanks and regards.
Here is my test:
GET /LEDON HTTP/1.1
Pragma: no-cache
HTTP/1.1 200 OK
Content-Length: 49
Connection: Closed
<blank line>
<blank line>
Content-Length: 49
Connection: Closed
Thanks and regards.
