- Sun Nov 12, 2006 10:19 pm
#21804
I'll bet you were using a germanium or Shockley diode whose drops are around .2 volt. But, I'm glad the pull-up brought the level up to the proper level. The pull-up is a better approach anyway. I really thought that getting the input levels where they're supposed to be would fix this.
I noticed that pins 5, 6, and 7 are connected in your receiver photo, but they aren't connected in your view of the entire breadboard. If you don't have +5 on 5, and GND on 6 and 7, you should hook them up.
Other than that, I can't see why this isn't working. Perhaps an email to Rentron describing the problem might help. Be sure to reference your oscilloscope measurements or this message thread. On their site, they show essentially the same setup as yours using the same parts.
