By sverrirbjarna
#189641
Im wondering if i can reduce the range of a bluetooth device or how it would be possible for me to make some kind of device that could only go a certain amount of meters from the source. And if i could set it on the go with an app or something.
By jremington
#189645
Geofencing with radio is difficult and not accurate. The best you can do is with GPS, and for consumer grade devices you are limited to at best 2-3 meters accuracy, when outdoors with a clear view of the sky.
By stevech
#189648
sverrirbjarna wrote:Im wondering if i can reduce the range of a bluetooth device or how it would be possible for me to make some kind of device that could only go a certain amount of meters from the source. And if i could set it on the go with an app or something.
Yes, geofencing is restricting movements to inside a polygon area.
Loss of signal at range x is easily done, but x will vary greatly, say, 10 to 1, depending the RF propagation impairments from walls, foliage, terrain, body-block, etc.
That's OK for some applications.
