By psppb
#188098
So after figuring out that GPIO pin 0 needed to be grounded tp program the "Thing" I attempted the simple Blync tutorial and the thing ain't working.
The COM serial port from the arduino IDE won't do anything at all unless I connect the sleep jumper which I soldered on. Then is spits out two things depending on GPIO 0's grounding
Without:
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
And when I ground it the boot mode problem is (1,7)
If the sleep jumper is removed... Nothing happens. No serial out period.
Internet says:
    reset causes:
        0:
        1: normal boot
        2: reset pin
        3: software reset
        4: watchdog reset
    boot device:
        0:
        1: ram
        3: flash
What in Gods name do I have to do to get this "Thing" working or is this just not w working board
Thanks
By Valen
#188142
psppb wrote:...
Can you give a bit more details on what you soldered and to where. And pictures to rule out shorts due to solder blobs. There is no sleep jumper pad on the board. Or did you mean that you soldered the reset-from-sleep pin GPIO16/XPD to DTR.
Like here: https://learn.sparkfun.com/tutorials/es ... sleep-mode
If so, note the warning that it needs to be un-jumpered to allow upload of code.
By Valen
#188143
Please clarify if this is a typo. Did you mean Blink, or Blynk?
The first, code shown in the hookup guide, doesn't send anything on the serial port. It only blinks the led on GPIO5.
The latter is a library/platform app to connect with your mobile phone/tablet. I wouldn't call that simple if you are just beginning with ESP8266.
