- Fri Aug 14, 2015 7:05 am
#184034
Hello. After reading the bluetooth tutorials I still have one question. Is it possible to hook up a bluetooth module supporting SPP profile directly to a USB memory stick, that let's say is plugged into my car audio, so I can transmit data files via bluetooth to the USB memory without the need of a computer?
Clarification:
I thought of soldering the RX & TX pins of the BT module to the data +/- pins from the USB memory stick. The USB memory stick and the BT module is then powered by the car's audio USB slot. The car's audio USB slot simply reads the content from the memory stick and plays audio files on the hifi.
Or do I need some kind of logic that manages the writing process to the USB memory. :think:
Clarification:
