- Sat May 23, 2015 2:05 pm
#182172
Hello SparkFun Forum.
THE SYSTEM:
2 year old Dell “business” desktop
Windows 7 with all updates
2 x brand new XBee PRO S1
1 x SparkFun XBee Explorer Dongle
1 x SparkFun XBee Arduino Shield+Arduino UNO V3 programmed with “XBee_Remote_Control.ino” from the SparkFun Xbee Shield Hookup Guide
https://learn.sparkfun.com/tutorials/xb ... 1426219622
XCTU – current version with compatibility mode set to Windows 7
THE PROBLEM:
Using the Serial Monitor and the XCTU Console (as in the Hookup Guide) everything seems to work OK
i.e. If I ask the “dongle XBee” to request the “Arduino Shield XBee” to read analog pin 0 “a0” it works (I have a LDR giving a varying voltage to Arduino pin A0).
But if I set the XCTU to send a repeating looped sequence of “a0” with 500uS delays it works for a couple of minutes then the XCTU console appears to freeze.
This often happens around 4000 to 5000 Rx bytes
The DIN and DOUT lights on the 2 XBees continue to operate which seems to suggest to me that they are still communicating. The top left hand Tx/Rx icon on the XCTU console has arrows going backwards and forwards indicating data transfer but the rest of the console is frozen.
See images.
http://imagizer.imageshack.us/v2/640x48 ... UsLWNq.jpg
http://imagizer.imageshack.us/v2/640x48 ... toKqNN.jpg
The only way to recover the situation is to close XCTU, remove the “dongle XBee” and start again.
I’ve reinstalled XCTU and swapped my first 2 XBee PRO for another new pair (I’d purchased 4 units) and still the same thing happens. …. What am I missing?
THE SYSTEM:
THE PROBLEM:
See images.
