- Tue Apr 29, 2014 12:43 am
#170629
Hey all,
I'm looking for some clarity on the type of RFID I should pursue for a project. I need a passive RFID that will give me a 2-3 foot read range.
I have not determined my power source yet, but it will be a Li-Ion battery of some sort. For now, I'll be using wall power, but I'll likely switch to an 18650.
Size wise, I'm hoping the antenna can stay under 1.5 inch x 2 inch.
Nothing like some simple constraints right?
I went ahead and purchased the SM130 and eval shield and only after I soldered them together did I discover the range is closer to one inch than one foot. Based on what I'd read about higher frequencies having longer read distances, I thought it was a better choice than the ID-12LA (Which only has a 120mm range).
Anyhow, if you have any suggestions as to which technology I could pursue, it would be much appreciated. Or if this is impossible, it'd be good to know that too!
Thanks,
Chris
Thanks,
Chris
