- Wed Feb 26, 2014 10:11 am
#168883
I encounter problems when I attempt to open connections with my RN-171 in HTML Client mode when the Access Point is a Samsung Galaxy S3 phone set as hotspot. Microchip Support has also replicated the issue with other Android phones.
[There is no problem when the Access Point is my home router.]
Instead of the "OPEN* reply from the WiFly module, there is only a "Connect FAILED" reply. Occasionally some connections reply with a *OPEN*, this happens only 1 out of 20 times or so. I reset the RN171 module after many failed connections, and then maybe I get 1 successful connection again out of many failed.
However, the interesting part is that if I connect my PC to the hotspot as well (the hotspot has two clients, both the PC and the WiFly) all connections from the RN171 are opened successfully.
Also, if I open a browser on the phone and load any page, the RN171 will open connections successfully for a limited period of time.
Is there someone who has encountered similar issues? And is there someone who uses hotspots as the access point with success?
Regards
HC
Regards
HC
