- Tue Feb 25, 2014 2:24 pm
#168850
We use sensors to measure groundwater parameters including level and temperature.
The level is measured by a pressure sensor connected by an optical cable to a translator to a USB port. The data is collected by proprietary software. The locations may be 3-400 feet remote from the PC. We need data that is realtime so we use optical cables. There may be multiple locations monitored simultaneously.
The sensor is battery powered, the optical to USB translator is USB powered.
I want to replace to cable with a RF . The remote transmitter should be battery powered. I want to replace just the USB cable which connects the optical cable to the USB port.
Not sure of the baud rate, the sensor updates once per minute. Does this seem like a viable possibility?
