By tom_in_az
#164836
Well, I am new to this stuff.... It took me days to just get a serial connection going. For you other newbies, if you are looking to just start off with a simple serial connection to your Uno, use this code.
The intended connection points on a Uno board is using Analog 4 & 5 (A4 & A5), otherwise known as Digital 18 & 19 (D18 & D19). Feel free to change these up, but try not to use D0 & D1 as those pins also share how the Uno is programed via USB.
 * Here is your code needed to make the RN-XV work with an Uno.
 * Take this code and use it to make your own sketches.
 * I am using Arduino IDE 1.0.5
#include <SoftwareSerial.h>
SoftwareSerial mySerial(18, 19); // RX, TX
void setup()
  // Open serial communications and wait for port to open:
  Serial.begin(9600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Serial Connection is go!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
By uChip
#164930
The RN-XV is the XBee-shaped board containing the Roving Networks WiFly module (RN-171). The naming between the board and the module is somewhat confusing. See SparkFun WRL-10822.
-Chip
By gcriniti
#167409
Thanks for posting this! I'm connected! I've been looking for quite some time for a way to get started with serial communication between my Uno and WiFly board. If you can offer any more assistance, it would be greatly appreciated. I want to write a Windows application to talk to another serial device connected to the Uno. -Greg
