- Tue Jul 09, 2013 9:25 am
#161367
I have been trying to communicate between three XBees, from an end device, to a router and finally to a coordinator.
My aim is to see the sensor value that is sent from the end device at the laptop (XCTU) connected to the coordinator.
I'm using XBee series 2 modules.
The end device is connected to a sensor board, while the router and coordinator are connected to two separate laptops using adaptor boards.
My first try was:
For end device: Program its DH and DL to the SH and SL of the Router
For router : Program its DH and DL to the SH and SL of the Coordinator
For Coordinator: Just left DH and DL blank
I expected to see the results on the coordinator, but the data was appearing only on the terminal of the laptop connected to the router.
How do I change this? I would like to move my coordinator around so I can do a range test, so I would like to see the data appearing on the laptop with the coordinator connected to it.
Thank you.
My first try was:
Thank you.
