- Tue Jul 02, 2013 7:32 pm
#161173
Hello Sparkfun community,
I have recently bought two Series 1, XB24-AUI-001 Xbee's, and two Arduino shields similar to this. I am attempting to use these to establish wireless communications between an Arduino Mega, and an Arduino Duemilanove. I have followed the instructions here, but got no success.
I thought that maybe I need to reset the chips, I placed both jumpers to USB, wrote an empty code to the Arduino, I opened up X-CTU, went to Modem Configuration, and clicked restore. On the bottom it wrote
"Resetting AT Commands...
Restore Defaults..complete".
I did the same to the other chip too. Still no communications in between them.
Next I tried to download new versions for the Function Set 802.15.4(Currently both are on 10E8). After a while it successfully downloaded all the way up to 10ED. Then I tried to write 10ED to one of them, it said
"Getting modem type....OK
Programming modem...Lost communication with modem
Write Parameters...Failed"
Some other information.
When the Xbee is placed on the shield a red LED starts blinking.
When I do a Query it says:
Communication with modem...OK
Modem firmware version = 10E8
Modem type = XB24
Serial Number = 13A2004062C846
Serial Number(For the second one)= 13A2004048dCE0
In Terminal it seems like +++ and all AT commands work.
Do I have to change the modem(currently XB24), or the Function Set(currently XBEE 802.15.4)?
Any help or pointers in the correct direction are much appreciated.
Modem type = XB24
