- Wed Jul 25, 2012 2:36 pm
#147813
Hi all!
Fast question regarding the WiFly RN-171 solution.
Firstly, I have it working...I can create an Adhoc network, telnet to just fine etc...see data etc.
This is what I REALLY want to do.
#1. Create a server on the RN-171; in other words, people would connect to this network (be it adhoc or AP based)
#2. The client end would go to a specific port (ie. 80) where they would send a "stream" of data (from a browser it would be HTTP data)
#3. My micro connected to the RN-171, would receive the data, parse and process it, and then send back a formatted HTML stream so the data can be rendered on the browser.
#4. I (the backend micro) need to process the data, and I just need the WiFly to be a "socket" <--> Serial proxy.
Can you recommend the best way to config this?
Also, can people use the serial at 38400 baud? For some reason, I cannot...9600 works just fine...and yes, I did update the new baud rate to the RN-171...
Thoughts?
~Kam
Thoughts?
~Kam
"Before you criticize someone, you should walk a mile in their shoes.
That way, when you criticize them, you're a mile away and you have their shoes."
