- Tue Jul 20, 2010 3:01 pm
#105676
I am looking to build a wireless data recording device that uses a DAQ board and a serial input to the computer. Right now, the system works just fine wired and plugged in to a standard USB 2.0 port. What I want to do is wirelessly bridge the sensor to the computer from a couple hundred feet away (hence the reason to try to remove wires).
From sparkfun.com I have looked at a few products that look promising:
Transmitter:
Power:
Polymer Lithium Battery (1 for each DAQ/sensor)
http://www.sparkfun.com/commerce/produc ... ts_id=8483
5V DC to DC Step Up - VPack PCB
http://www.sparkfun.com/commerce/produc ... ts_id=8290
With this setup I estimated that I could get 5V at 300mA for 4 hours. Correct me if I am wrong. The goal of this is to power a DAQ board and sensor through a USB connection as well as power the RF transmitter.
RF Transmitter:
RF Link Transmitter - 434MHz
http://www.sparkfun.com/commerce/produc ... ts_id=8946
ProtoBoard - Square 2"
http://www.sparkfun.com/commerce/produc ... ts_id=8811
The DAQ will connect to the transmitter through a standard Female USB connector.
Receiver:
This will be powered through a computer’s (Laptop) USB port.
RF Link 4800bps Receiver - 434MHz
http://www.sparkfun.com/commerce/produc ... ts_id=8950
Proto Breadboard - Rectangle Wired 3"
http://www.sparkfun.com/commerce/produc ... ts_id=8812
The intended use of this is merely wirelessly bridge a gap between a single sensor and the computer that will be recording data.
Any help would be helpful (i.e. If this setup is feasible).
If this is not feasible, are there any better methods you would recommend?
Transmitter:
Power:
RF Transmitter:
Receiver:
