- Sat Feb 06, 2010 3:32 pm
#92868
I'm working with the SM5100B GSM/GPRS module and I have some questions. The datasheet is pretty awful: http://www.sparkfun.com/datasheets/Cell ... Manual.pdf
Page 24: How would I wire the battery charging interface? What's shown on the datasheet doesn't make any sense to me.
Page 22: Is the reset pin pulled high internally or not? How should I wire the reset pin (active low) to be controllable from an atmega?
Page 19: The UART is described to be used only by "ARM." I assume that means arm processors, though I don't know why that would be. Do I have to use the flow control lines on UART0? I'm only sending AT commands and getting replies from the module
Thanks. I hope i can get this figured out soon, i'm in a little bit of a time crunch
