- Tue Oct 06, 2009 8:40 am
#82456
Just received a BlueSMiRF and I have no problems pairing or issuing commands. The problem begins when when sending data. It send data for 3-5 minutes and then the data transmission stops. In order to get it working again I have to disconnect the tx and rx from the UART ports, reconnect to the SMiRF via teraterm, and then reconnect the rx/tx (while still connected to the COM port via teraterm). As soon as the rx and tx are connected data starts flowing for a few minutes and then the whole cycle repeats itself.
I'm pretty new to embedded systems. Is this the way a BlueSMiRF should be working? Any ideas what may be the issue?
Any insight would be greatly appreciated.
