I've put this code up in a few other places, but posting here so that if I make any changes you can come here to see my progress.
I had some trouble getting some of the other example code for the nRF24AP1 working so I decided to work through it myself. I do not have it completely working yet but I do have the chip communicating and everything with my program so, its a good start!
Github: https://github.com/smysnk/garmin-heart-rate-monitor
Update: The code should now work! People using the sparkfun FOB will need to adjust global.h with the proper baud rate of 4800
Here is the output of my program:
root@syndsys-vmware:/home/sammy/ANT# ./ant /dev/ttyUSB0
TX: Success
txda: a4 01 4a 00 ef
TX: Success
txda: a4 02 4d 00 54 bf
TX: Success
RX: [sync]..[0x04]..[0x54]..[0x04]..[0x03]..[0x00]..[0x03]..[0xf0]
RX: msg received [7]
[DEBUG] Device Capabilites
Max Ch 4
Max Networks 3
Standard Opts 0x00
Advanced Opts1 0x03 [NETWORK_EN]
Advanced Opts2 0x00
Max Data Ch 0
txda: a4 02 4d 00 3d d6
TX: Success
RX: [sync]..[0x03]..[0x40]..[0x00]..[0x4d]..[0x28]..[0x82]
RX: msg received [6]
Response Handler (size=3)
Channel Num 0x00
Message ID 0x4d [unknown]
Message Code 0x28
txda: a4 03 42 00 00 01 e4
TX: Success
RX: [sync]..[0x03]..[0x40]..[0x00]..[0x42]..[0x00]..[0xa5]
Channel Num 0x00
Message ID 0x42 [MESG_ASSIGN_CHANNEL_ID]
Message Code 0x00
new txda: a4 05 51 00 00 00 00 00 f0
old txda: a4 04 51 00 00 00 00 f1 --- Here was my problem!
TX: Success
RX: [sync]..[0x03]..[0x40]..[0x00]..[0x51]..[0x00]..[0xb6]
Channel Num 0x00
Message ID 0x51 [MESG_CHANNEL_ID_ID]
Message Code 0x00
txda: a4 09 46 01 b9 a5 21 fb bd 72 c3 45 65
TX: Success
RX: [sync]..[0x03]..[0x40]..[0x01]..[0x46]..[0x00]..[0xa0]
Channel Num 0x01
Message ID 0x46 [MESG_NETWORK_KEY_ID]
Message Code 0x00
txda: a4 02 44 00 0a e8
TX: Success
RX: [sync]..[0x03]..[0x40]..[0x00]..[0x44]..[0x00]..[0xa3]
Channel Num 0x00
Message ID 0x44 [MESG_CHANNEL_SEARCH_TIMEOUT_ID]
Message Code 0x00
txda: a4 02 45 00 39 da
TX: Success
RX: [sync]..[0x03]..[0x40]..[0x00]..[0x45]..[0x00]..[0xa2]
Channel Num 0x00
Message ID 0x45 [MESG_CHANNEL_RADIO_FREQ_ID]
Message Code 0x00
txda: a4 03 43 00 1f 86 7d
TX: Success
RX: [sync]..[0x03]..[0x40]..[0x00]..[0x43]..[0x00]..[0xa4]
Channel Num 0x00
Message ID 0x43 [MESG_CHANNEL_MESG_PERIOD_ID]
Message Code 0x00
txda: a4 01 4b 00 ee
TX: Success
RX: [sync]..[0x03]..[0x40]..[0x00]..[0x4b]..[0x00]..[0xac]
Channel Num 0x00
Message ID 0x4b [MESG_OPEN_CHANNEL_ID]
Message Code 0x00
RX: [sync]..[0x03]..[0x40]..[0x00]..[0x01]..[0x01]..[0xe7]
Channel Num 0x00
Message ID 0x01 [unknown]
Message Code 0x01
