- Mon May 04, 2009 4:20 pm
#72003
I can use a USB to Serial adaptor to program using the provided bootloader so I assumed that the Bluesmirf silver would work too.
However the bootloader doesnt seem to be able to program when using the BT SPP.
Is there a reason this isnt possible or am I doing something wrong? I simply connected the BT serial to the pic serial and gave both modules a connection to the same power supply.
I can connect the serial port ok, send and receive data to and from the pic with existing code, when I try to program it I get strange errors.
www.pyrofersprojects.com
