- Tue Aug 05, 2008 1:17 am
#53165
Hello everyone~
These days I'm working on a project using ATmega32 and nRF24L01 to transmit data. And after studying the technical reference, I have got some questions about nRF24L01.
Q1: Is it correct if I use the following commands to write "Tx Payload":
CSN_low SPI_Command"0xA0" then " Payload data" then CSN_High? Can I do these commands either CE is high or low ?
Q2: When I want to transmit a data package, I have to "Keep CE high at least 10us". What will happen if I always keep the "CE" pin high?
Q3: These are the following words in the technical reference that made me so confused " Page 14. Enhanced ShockBurst Transmitting Payload.
Point 6. The device goes into Standby_1 Mode if CE is low. Otherwise the next payload in TX FIFO will be sent. If TX FIFO is empty and CE is still high,the device will enter Standby_2 Mode."
What does it mean by " the next payload in TX FIFO will be sent"? Does it have another TX FIFO or just means something else?
And thank you all guys~ Hope to hear some replies~~lol
