- Wed Jul 30, 2008 9:31 pm
#52927
Situation as follows:
I have the Firefly set in Auto Master mode.
I am trying to save a remote address in the Firefly BT module. I do the old "SR,remote address" command and get back AOK.
I then do the R,1 command to reboot, as it says "***SET COMMANDS***stored in flash, and only take effect AFTER reboot"
I then power off the module and set the DIP switches with
1, off
2, on
3, on
4, off
I then power up my firefly (master) and another sparkfun BT module I have (slave) and no connection gets made.
When I do the D command it shows all the correct settings for Baud rate, Mode, etc, but does not save the remote address I had entered previously.
Although, right after I set the remote address using the SR command and then do the C command, the firefly connects to the other BT module.
I want the firefly to connect to its slave (which I have set as slave) automatically. Neither BT device has authentication or encryption enabled.
Question:
What am I missing or doing incorrectly. Can anyone help please
1, off
2, on
3, on
4, off
Question:
