- Wed Apr 16, 2008 11:57 pm
#46555
Hi, I have recently got my Witilt 2.5 talking to my OS X 10.5 machine via Matlab and the Psychtoolbox (support for serial comms in OS X version of matlab is poor but SerialComm or Comm seem to work).
I am able to stream Raw or G data successfully at 10Hz but if push the acquisition rate to as low as 50Hz I start to experience some dropout of data or what appears to be insertion of points. I assume that there is probably something wrong with my sampling in code.
Essentially I start the witilt streaming, then in a while loop (I acquire for 5 sec), then do a short while loop that waits for an acqusition rate sample, then purge the buffer, then read the buffer. See below
SerialComm('open',port_num,'57600,n,8,1');
WaitSecs(2);
SerialComm('write',port_num,'1');
start=GetSecs;
buffer=[];
n=0;
while GetSecs-start<5
n=n+1;
s=GetSecs;
SerialComm('purge',port_num);
while
GetSecs-s<(1/sample_rate);
end
d=SerialComm('read',port_num);
time(n)=GetSecs-start;
buffer = [buffer d'];
end
SerialComm('write',port_num,32);
SerialComm('close',port_num);
Any comments appreciated.
Cheers
stu
WaitSecs(2);
start=GetSecs;
buffer=[];
n=0;
n=n+1;
s=GetSecs;
while
end
end
Cheers
stu
