- Tue Apr 15, 2008 6:59 pm
#46499
So I am using the ID-12 to read RFID tags. I need to send the tag ID wirelessly less to a board across the room(a few feet away). I had originally tried using the RF-Link ASK(http://www.sparkfun.com/commerce/produc ... ts_id=7816) transmitter/receiver pair. However, this does not like any of the TTL output I feed it from a PIC(not directly from the ID12 because of baud issues) and seems to have tons of noise.
To navigate around this problem I was looking at the XBee module because I am outputting UART from the ID-12 and the popular XBee looks like it will fit my project perfectly. I was just wondering, do I need to buy an expensive board to program this thing, or if I just buy the XBee 1mW Chip Antenna(http://www.sparkfun.com/commerce/produc ... ts_id=8664) will it work for point-to-point UART transmission like I need? The data sheet is a bit fuzzy about how to program it, and mentions a "professional developers kit". However, at the beginning of the spec sheet it says that by default the XBee module works like a UART wire replacer. So for my project I can just use this module without having to buy any programming boards, correct?
Thanks, -WK
Thanks, -WK
