- Mon Apr 07, 2008 8:24 am
#45965
Ok, I have done my homework. This is my"I'm Learning" setup, of which when I get it working, I will be able transmute the code into a bigger system I am working on. I have a sender pic16f877 with a switch for sending a single payload to a pic16f877 receiver. I have the SPI code working where I know that the pics are talking to the MirfV2's. I have verified this with my HobbyLAB PC Oscillo/Logic anaylizer. My goal is real simple in this code: send 5 bytes and receive 5 bytes. I have been working on this since january..had to teach myself SPI...and doing it on about 5-10 hrs/week. Been through much frustration and success (with SPI), but I am sure that all i need is a few tweeks for probably obvious reasons.
ANY HELP!! would be much appreciated!!
THnx in Advance
Harold G.
Here's the code:
SENDER:
'* Name : MirfTransT2.BAS *
'* Author : Harold Goodrich *
'* Notice : Copyright (c) 2008 Harold Goodrich *
'* : All Rights Reserved *
'* Date : 4/2/2008 *
'* Version : 1.0 *
'* Notes : *
define OSC 10
INCLUDE "modedefs.bas"
spin VAR PORTD.6
LED VAR PORTD.2
LED1 VAR PORTD.3
TRISD.2=0
TRISD.3=0
TRISD.6=0
low LED
low LED1
i VAR BYTE 'loop counter
ThisReg var byte
ThisCmd var byte
Temp var byte
RecData var byte[4]
SendData var byte[4]
'Mirf Config
REG_CONFIG var byte
REG_CONFIG=%00000000
PRIM_RX var REG_CONFIG.0
PWR_UP var REG_CONFIG.1
CRC0 var REG_CONFIG.2
EN_CRC var REG_CONFIG.3
R_REG_CONFIG con %00000000
W_REG_CONFIG con %00100000
REG_EN_AA var byte
REG_EN_AA = %0011111
ENAA_P5 var REG_EN_AA.5
ENAA_P4 var REG_EN_AA.4
ENAA_P3 var REG_EN_AA.3
ENAA_P2 var REG_EN_AA.2
ENAA_P1 var REG_EN_AA.1
ENAA_P0 var REG_EN_AA.0
R_REG_EN_AA con %00000001
W_REG_EN_AA con %00100001
REG_EN_RXADDR var byte
REG_EN_RXADDR=%0000000
ERX_P5 var REG_EN_RXADDR.5
ERX_P4 var REG_EN_RXADDR.4
ERX_P3 var REG_EN_RXADDR.3
ERX_P2 var REG_EN_RXADDR.2
ERX_P1 var REG_EN_RXADDR.1
ERX_P0 var REG_EN_RXADDR.0
R_REG_EN_RXADDR con %00000010
W_REG_EN_RXADDR con %00100010
REG_SETUP_AW var byte
REG_SETUP_AW=%00000011
R_REG_SETUP_AW con %00000011
W_REG_SETUP_AW con %00100011
REG_SETUP_RETR var byte
REG_SETUP_RETR=%00000011
'ARD: 7:4 250Us each increment
'This is the time the PTX is waiting for an ACK packet before a retransmit is made. The PTX is in RX mode
'for a minimum of 250?S, but it stays in RX mode to the end of the packet if that is longer than 250?S. Then
'it goes to standby-I mode for the rest of the specified ARD. After the ARD it goes to TX mode and then
'retransmits the packet.
'ARC 3:0 retry count 0 to 15, 0 is disabled
R_REG_SETUP_RETR con %00000100
W_REG_SETUP_RETR con %00100100
RF_CH var byte
RF_CH=%00000010
R_REG_RF_CH con %00000101
W_REG_RF_CH con %00100101
REG_RF_SETUP var byte
REG_RF_SETUP=%00001111
LNA_HCURR var REG_RF_SETUP.0 'gain
'RF_PWR 2:1, 11=0db, 10:-6db, 01:-12db, 00:-18db
R_REG_RF_SETUP con %00000110
W_REG_RF_SETUP con %00100110
REG_STATUS var byte
REG_STATUS=%00001100
RX_DR var REG_STATUS.6
'The RX_DR IRQ is asserted by a new packet arrival event. The procedure for handling this interrupt
'should be: 1) read payload through SPI, 2) clear RX_DR IRQ, 3) read FIFO_STATUS to check if there
'are more payloads available in RX FIFO, 4) if there are more data in RX FIFO, repeat from 1)
TX_DS VAR REG_STATUS.5
MAX_RT var REG_STATUS.4
'RX_P_NO is bits 3:1 000-101 DataPipe#, 110=not used, 111=FIFO empty
TX_FULL var REG_STATUS.0
R_REG_STATUS con %00000110
W_REG_STATUS con %00100110
'TX_ADDR 39:0
TX_ADDR VAR byte[5]
R_TX_ADDR con %00010000
W_TX_ADDR con %00110000
'RX_ADDR_P0 39:0
RX_ADDR_P0 VAR byte[5]
R_RX_ADDR_P0 con %00001010
W_RX_ADDR_P0 con %00101010
'RX_ADDR_P1 39:0
RX_ADDR_P1 VAR byte[5]
R_RX_ADDR_P1 con %00001011
W_RX_ADDR_P1 con %00101011
RX_ADDR_P2 var byte
RX_ADDR_P2=%00000000
R_RX_ADDR_P2 con %00001100
W_RX_ADDR_P2 con %00101100
RX_ADDR_P3 var byte
RX_ADDR_P3=%00000000
R_RX_ADDR_P3 con %00001101
W_RX_ADDR_P3 con %00101101
RX_ADDR_P4 var byte
RX_ADDR_P4=%00000000
R_RX_ADDR_P4 con %00001110
W_RX_ADDR_P4 con %00101110
RX_ADDR_P5 var byte
RX_ADDR_P5=%00000000
R_RX_ADDR_P5 con %00001111
W_RX_ADDR_P5 con %00101111
RX_PW_P0 var byte '5:0 is #bytes in payload, 1 to 32 bytes
RX_PW_P0=%00000000
R_RX_PW_P0 con %00010001
W_RX_PW_P0 con %00110001
RX_PW_P1 var byte '5:0 is #bytes in payload, 1 to 32 bytes
RX_PW_P1=%00000000
R_RX_PW_P1 con %00010010
W_RX_PW_P1 con %00110010
RX_PW_P2 var byte '5:0 is #bytes in payload, 1 to 32 bytes
RX_PW_P2=%00000000
R_RX_PW_P2 con %00010011
W_RX_PW_P2 con %00110011
RX_PW_P3 var byte '5:0 is #bytes in payload, 1 to 32 bytes
RX_PW_P3=%00000000
R_RX_PW_P3 con %00010100
W_RX_PW_P3 con %00110100
RX_PW_P4 var byte '5:0 is #bytes in payload, 1 to 32 bytes
RX_PW_P4=%00000000
R_RX_PW_P4 con %00010101
W_RX_PW_P4 con %00110101
RX_PW_P5 var byte '5:0 is #bytes in payload, 1 to 32 bytes
RX_PW_P5=%00000000
R_RX_PW_P5 con %00010110
W_RX_PW_P5 con %00110110
REG_FIFO_STATUS var byte
REG_FIFO_STATUS=%00000000
TX_REUSE var REG_FIFO_STATUS.6
FIFO_TX_FULL var REG_FIFO_STATUS.5
FIFO_TX_EMPTY var REG_FIFO_STATUS.4
RX_FULL var REG_FIFO_STATUS.1
RX_EMPTY var REG_FIFO_STATUS.0
R_REG_FIFO_STATUS con %00010111
W_REG_FIFO_STATUS con %00110111
DYNPD var byte
DYNPD = %00000000
DPL_P0 var DYNPD.0
DPL_P1 var DYNPD.1
DPL_P2 var DYNPD.2
DPL_P3 var DYNPD.3
DPL_P4 var DYNPD.4
DPL_P5 var DYNPD.5
R_DYNPD con %00011100
W_DYNPD con %00111100
FEATURE var byte
'To activate this feature use the ACTIVATE SPI command followed by data 0x73.(1110011) The corresponding bits
'in the FEATURE register must be set.
FEATURE = %00000000
EN_DYN_ACK var FEATURE.0
EN_ACK_PAY var FEATURE.1
'If ACK packet payload is activated, ACK packets have dynamic payload lengths and the Dynamic Payload
'Length feature should be enabled for pipe 0 on the PTX and PRX. This is to ensure that they receive
'the ACK packets with payloads. If the payload in ACK is more than 15 byte in 2Mbps mode the ARD must
'be 500?S or more, and if the payload is more than 5byte in 1Mbps mode the ARD must be 500?S or more.
EN_DPL var FEATURE.2
R_FEATURE con %00011101
W_FEATURE con %00111101
R_RX_PAYLOAD con %01100001
W_TX_PAYLOAD con %10100000
FLUSH_TX con %11100001
FLUSH_RX con %11100010
ACTIVATE CON %01010000
R_RX_PL_WID con %01100000
W_ACK_PL_P0 con %10101000
W_ACK_PL_P1 con %10101001
W_ACK_PL_P2 con %10101010
W_ACK_PL_P3 con %10101011
W_ACK_PL_P4 con %10101100
W_ACK_PL_P5 con %10101101
W_TX_PL_NO_ACK con %10110000
NOP con %11111111
CE var PORTC.0
CSN var PORTC.1
IRQ var PORTB.4
TRISB.4=1
high CSN
low CE
'SPI Config
TRISC=%00010000
SSPEN VAR SSPCON.5 'SSP Enable bit
CKP VAR SSPCON.4 'Clock Polarity Select
SMP VAR SSPSTAT.7 'Data input sample phase
CKE VAR SSPSTAT.6 'Clock Edge Select bit
SSPIF VAR PIR1.3 'SPI interrupt flag
BF var SSPSTAT.0 'Buffer Full
SSPCON.0=0
SSPCON.1=1
SSPCON.2=0
SSPCON.3=0
SSPEN = 1 'enable SPI pins
CKP = 0 'clock idle low
CKE = 0 'transmit on idle to active transition
SSPIF = 0 'clear buffer full status
SMP = 0 'sample in middle of data
Bttn VAR PORTD.0
TRISD.0=1
TxSent var bit
TxSent=0
WaitForMirf:
High LED
if IRQ=0 then WaitForMirf
pause 500
Low LED
PRIM_RX=1
gosub SetUPMirfV2
SendData[0]="A"
SendData[1]="B"
SendData[2]="C"
SendData[3]="D"
SendData[4]="E"
loop:
if Bttn=1 then
gosub SendTXPayload
TxSent=1
endif
if TxSent=1 then
pause 1000
TxSent=0
endif
goto loop
end
GetIncoming:
high LED
if SSPIF=0 then GetIncoming
if BF=0 then GetIncoming
PauseUs 25 '25uS fudge factor
Temp=SSPBUF
SSPIF=0
Low LED
return
SetForRXTXNoSB:
'PRIM_RX=1 or PRIM_RX=0 set before sub called
pauseus 10
if PRIM_RX=1 then
'CE for RX mode
high CE
else
'CE for TX Mode
low CE
endif
return
GetRegister:
low CSN
pauseus 10
SSPBUF=ThisCmd
gosub GetIncoming
pauseus 10
SSPBUF=NOP
gosub GetIncoming
ThisReg=Temp
High CSN
return
SetGetReg:
low CSN
pauseus 10
SSPBUF=ThisCmd
gosub GetIncoming
pauseus 10
SSPBUF=ThisReg
gosub GetIncoming
High CSN
return
Set5byteAddress:
LOW CSN
pauseus 10
SSPBUF=W_TX_ADDR
gosub GetIncoming
for i = 0 to REG_SETUP_AW
SSPBUF=TX_ADDR
gosub GetIncoming
next
HIGH CSN
pauseus 10
LOW CSN
SSPBUF=RX_ADDR_P0
gosub GetIncoming
next
HIGH CSN
return
CheckIRQLED:
if IRQ =0 then
low LED1
SerOut spin,N2400,["I",10,13]
else
high LED1
endif
SendTXPayload:
high led
low CSN
pauseus 10
SSPBUF=W_TX_Payload
Gosub GetIncoming
for i = 0 to 4
SSPBUF=SendData
Gosub GetIncoming
next
high CE
pauseus 20
low CE
pauseus 20
high CSN
low led
return
ReadRXPayload:
low CE
low CSN
SSPBUF=R_RX_Payload
Gosub GetIncoming
for i = 0 to 4
SSPBUF=NOP
Gosub GetIncoming
RecData=Temp
SerOut spin,N2400,["R",#RecData,"D",10,13]
next
high CSN
RX_DR=1
ThisCmd=W_REG_STATUS
ThisReg=REG_STATUS
gosub SetGetReg
high CE
return
SetUPMirfV2:
REG_SETUP_AW=5
ThisCmd=W_REG_SETUP_AW
ThisReg=REG_SETUP_AW
gosub SetGetReg
TX_ADDR[0]=%01001001
TX_ADDR[1]=%10001101
TX_ADDR[2]=%00111001
TX_ADDR[3]=%11001101
TX_ADDR[4]=%01101100
RX_ADDR_P0=TX_ADDR
gosub Set5byteAddress
ENAA_P0=1
ThisCmd=W_REG_EN_AA
ThisReg=REG_EN_AA
gosub SetGetReg
ERX_P0=1
ThisCmd=W_REG_EN_RXADDR
ThisReg=REG_EN_RXADDR
gosub SetGetReg
REG_SETUP_RETR=%00011010
'500µs + 86µs, 10 retrans
ThisCmd=W_REG_SETUP_RETR
ThisReg=REG_SETUP_RETR
gosub SetGetReg
RF_CH=40
ThisCmd=W_REG_RF_CH
ThisReg=RF_CH
gosub SetGetReg
'TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR
ThisCmd=W_REG_RF_SETUP
ThisReg=REG_RF_SETUP
gosub SetGetReg
PWR_UP=1
CRC0=1
EN_CRC=1
ThisCmd=W_REG_CONFIG
ThisReg=REG_CONFIG
gosub SetGetReg
pause 2
return
RECEIVER:
'* Name : MirfRecT2.BAS *
'* Version : 1.0 *
'* Notes : *
define OSC 10
spin VAR PORTD.6
LED VAR PORTD.2
LED1 VAR PORTD.3
TRISD.2=0
TRISD.3=0
TRISD.6=0
low LED
low LED1
ThisReg var byte
ThisCmd var byte
Temp var byte
RecData var byte[4]
'Mirf Config
REG_CONFIG var byte
REG_EN_AA var byte
RF_CH var byte
RF_CH=%00000010
REG_STATUS var byte
'TX_ADDR 39:0
TX_ADDR VAR byte[5]
'RX_ADDR_P0 39:0
'RX_ADDR_P1 39:0
RX_ADDR_P2 var byte
RX_ADDR_P3 var byte
RX_ADDR_P4 var byte
RX_ADDR_P5 var byte
RX_PW_P0=%00000000
RX_PW_P1=%00000000
RX_PW_P2=%00000000
RX_PW_P3=%00000000
RX_PW_P4=%00000000
RX_PW_P5=%00000000
DYNPD var byte
DYNPD = %00000000
DPL_P0 var DYNPD.0
DPL_P1 var DYNPD.1
DPL_P2 var DYNPD.2
DPL_P3 var DYNPD.3
DPL_P4 var DYNPD.4
DPL_P5 var DYNPD.5
FEATURE var byte
FEATURE = %00000000
NOP con %11111111
CE var PORTC.0
CSN var PORTC.1
IRQ var PORTB.4
TRISB.4=1
high CSN
low CE
'SPI Config
TRISC=%00010000
SSPCON.0=0
SSPCON.1=1
SSPCON.2=0
SSPCON.3=0
'Bttn VAR PORTD.0
'TRISD.0=1
High LED
WaitForMirf:
pause 500
Low LED
PRIM_RX=0
gosub SetUPMirfV2
loop:
if IRQ=1 then
ThisCmd=R_REG_STATUS
ThisReg=NOP
gosub SetGetReg
REG_STATUS=Temp
if RX_DR=1 then
high LED
gosub ReadRXPayload
low LED
endif
endif
goto loop
end
GetIncoming:
high LED
Temp=SSPBUF
SSPIF=0
Low LED
return
SetForRXTXNoSB:
pauseus 10
if PRIM_RX=1 then
'CE for RX mode
high CE
else
'CE for TX Mode
low CE
endif
return
GetRegister:
low CSN
pauseus 10
SSPBUF=ThisCmd
gosub GetIncoming
pauseus 10
SSPBUF=NOP
gosub GetIncoming
ThisReg=Temp
High CSN
return
SetGetReg:
low CSN
pauseus 10
SSPBUF=ThisCmd
gosub GetIncoming
pauseus 10
SSPBUF=ThisReg
gosub GetIncoming
High CSN
return
Set5byteAddress:
LOW CSN
pauseus 10
SSPBUF=W_TX_ADDR
gosub GetIncoming
SSPBUF=TX_ADDR
gosub GetIncoming
next
HIGH CSN
pauseus 10
LOW CSN
SSPBUF=RX_ADDR_P0
gosub GetIncoming
next
HIGH CSN
return
CheckIRQLED:
if IRQ =0 then
low LED1
else
high LED1
endif
SendTXPayload:
high led
low CSN
pauseus 10
SSPBUF=W_TX_Payload
Gosub GetIncoming
for i = 0 to 4
SSPBUF=SendData
Gosub GetIncoming
next
high CE
pauseus 20
low CE
pauseus 20
high CSN
low led
return
ReadRXPayload:
low CE
low CSN
SSPBUF=R_RX_Payload
Gosub GetIncoming
for i = 0 to 4
SSPBUF=NOP
Gosub GetIncoming
RecData=Temp
next
high CSN
RX_DR=1
ThisReg=REG_STATUS
gosub SetGetReg
high CE
return
SetUPMirfV2:
REG_SETUP_AW=5
gosub SetGetReg
RX_ADDR_P0=TX_ADDR
ENAA_P0=1
ThisCmd=W_REG_EN_AA
ThisReg=REG_EN_AA
gosub SetGetReg
ERX_P0=1
gosub SetGetReg
gosub SetGetReg
RF_CH=40
ThisCmd=W_REG_RF_CH
ThisReg=RF_CH
gosub SetGetReg
gosub SetGetReg
PWR_UP=1
CRC0=1
EN_CRC=1
ThisReg=REG_CONFIG
gosub SetGetReg
pause 2
return
THnx in Advance
Harold G.
Here's the code:
SENDER:
'* Version : 1.0 *
'* Notes : *
define OSC 10
spin VAR PORTD.6
LED VAR PORTD.2
LED1 VAR PORTD.3
TRISD.2=0
TRISD.3=0
TRISD.6=0
low LED
low LED1
ThisReg var byte
ThisCmd var byte
Temp var byte
RecData var byte[4]
'Mirf Config
REG_CONFIG var byte
REG_EN_AA var byte
RF_CH var byte
RF_CH=%00000010
REG_STATUS var byte
'TX_ADDR 39:0
TX_ADDR VAR byte[5]
'RX_ADDR_P0 39:0
'RX_ADDR_P1 39:0
RX_ADDR_P2 var byte
RX_ADDR_P3 var byte
RX_ADDR_P4 var byte
RX_ADDR_P5 var byte
RX_PW_P0=%00000000
RX_PW_P1=%00000000
RX_PW_P2=%00000000
RX_PW_P3=%00000000
RX_PW_P4=%00000000
RX_PW_P5=%00000000
DYNPD var byte
DYNPD = %00000000
DPL_P0 var DYNPD.0
DPL_P1 var DYNPD.1
DPL_P2 var DYNPD.2
DPL_P3 var DYNPD.3
DPL_P4 var DYNPD.4
DPL_P5 var DYNPD.5
FEATURE var byte
FEATURE = %00000000
NOP con %11111111
CE var PORTC.0
CSN var PORTC.1
IRQ var PORTB.4
TRISB.4=1
high CSN
low CE
'SPI Config
TRISC=%00010000
SSPCON.0=0
SSPCON.1=1
SSPCON.2=0
SSPCON.3=0
Bttn VAR PORTD.0
TRISD.0=1
TxSent var bit
TxSent=0
WaitForMirf:
High LED
pause 500
Low LED
PRIM_RX=1
gosub SetUPMirfV2
SendData[0]="A"
SendData[1]="B"
SendData[2]="C"
SendData[3]="D"
SendData[4]="E"
loop:
if Bttn=1 then
gosub SendTXPayload
TxSent=1
endif
if TxSent=1 then
pause 1000
TxSent=0
endif
goto loop
end
GetIncoming:
high LED
Temp=SSPBUF
SSPIF=0
Low LED
return
SetForRXTXNoSB:
pauseus 10
if PRIM_RX=1 then
'CE for RX mode
high CE
else
'CE for TX Mode
low CE
endif
return
GetRegister:
low CSN
pauseus 10
SSPBUF=ThisCmd
gosub GetIncoming
pauseus 10
SSPBUF=NOP
gosub GetIncoming
ThisReg=Temp
High CSN
return
SetGetReg:
low CSN
pauseus 10
SSPBUF=ThisCmd
gosub GetIncoming
pauseus 10
SSPBUF=ThisReg
gosub GetIncoming
High CSN
return
Set5byteAddress:
LOW CSN
pauseus 10
SSPBUF=W_TX_ADDR
gosub GetIncoming
SSPBUF=TX_ADDR
gosub GetIncoming
next
HIGH CSN
pauseus 10
LOW CSN
SSPBUF=RX_ADDR_P0
gosub GetIncoming
next
HIGH CSN
return
CheckIRQLED:
if IRQ =0 then
low LED1
else
high LED1
endif
SendTXPayload:
high led
low CSN
pauseus 10
SSPBUF=W_TX_Payload
Gosub GetIncoming
for i = 0 to 4
SSPBUF=SendData
Gosub GetIncoming
next
high CE
pauseus 20
low CE
pauseus 20
high CSN
low led
return
ReadRXPayload:
low CE
low CSN
SSPBUF=R_RX_Payload
Gosub GetIncoming
for i = 0 to 4
SSPBUF=NOP
Gosub GetIncoming
RecData=Temp
next
high CSN
RX_DR=1
ThisReg=REG_STATUS
gosub SetGetReg
high CE
return
SetUPMirfV2:
REG_SETUP_AW=5
gosub SetGetReg
RX_ADDR_P0=TX_ADDR
ENAA_P0=1
ThisCmd=W_REG_EN_AA
ThisReg=REG_EN_AA
gosub SetGetReg
ERX_P0=1
gosub SetGetReg
gosub SetGetReg
RF_CH=40
ThisCmd=W_REG_RF_CH
ThisReg=RF_CH
gosub SetGetReg
gosub SetGetReg
PWR_UP=1
CRC0=1
EN_CRC=1
ThisReg=REG_CONFIG
gosub SetGetReg
pause 2
return
RECEIVER:
'* Version : 1.0 *
'* Notes : *
define OSC 10
spin VAR PORTD.6
LED VAR PORTD.2
LED1 VAR PORTD.3
TRISD.2=0
TRISD.3=0
TRISD.6=0
low LED
low LED1
ThisReg var byte
ThisCmd var byte
Temp var byte
RecData var byte[4]
'Mirf Config
REG_CONFIG var byte
REG_EN_AA var byte
RF_CH var byte
RF_CH=%00000010
REG_STATUS var byte
'TX_ADDR 39:0
TX_ADDR VAR byte[5]
'RX_ADDR_P0 39:0
'RX_ADDR_P1 39:0
RX_ADDR_P2 var byte
RX_ADDR_P3 var byte
RX_ADDR_P4 var byte
RX_ADDR_P5 var byte
RX_PW_P0=%00000000
RX_PW_P1=%00000000
RX_PW_P2=%00000000
RX_PW_P3=%00000000
RX_PW_P4=%00000000
RX_PW_P5=%00000000
DYNPD var byte
DYNPD = %00000000
DPL_P0 var DYNPD.0
DPL_P1 var DYNPD.1
DPL_P2 var DYNPD.2
DPL_P3 var DYNPD.3
DPL_P4 var DYNPD.4
DPL_P5 var DYNPD.5
FEATURE var byte
FEATURE = %00000000
NOP con %11111111
CE var PORTC.0
CSN var PORTC.1
IRQ var PORTB.4
TRISB.4=1
high CSN
low CE
'SPI Config
TRISC=%00010000
SSPCON.0=0
SSPCON.1=1
SSPCON.2=0
SSPCON.3=0
'Bttn VAR PORTD.0
'TRISD.0=1
High LED
WaitForMirf:
pause 500
Low LED
PRIM_RX=0
gosub SetUPMirfV2
loop:
if IRQ=1 then
ThisReg=NOP
gosub SetGetReg
REG_STATUS=Temp
if RX_DR=1 then
high LED
gosub ReadRXPayload
low LED
endif
endif
goto loop
end
GetIncoming:
high LED
Temp=SSPBUF
SSPIF=0
Low LED
return
SetForRXTXNoSB:
pauseus 10
if PRIM_RX=1 then
'CE for RX mode
high CE
else
'CE for TX Mode
low CE
endif
return
GetRegister:
low CSN
pauseus 10
SSPBUF=ThisCmd
gosub GetIncoming
pauseus 10
SSPBUF=NOP
gosub GetIncoming
ThisReg=Temp
High CSN
return
SetGetReg:
low CSN
pauseus 10
SSPBUF=ThisCmd
gosub GetIncoming
pauseus 10
SSPBUF=ThisReg
gosub GetIncoming
High CSN
return
Set5byteAddress:
LOW CSN
pauseus 10
SSPBUF=W_TX_ADDR
gosub GetIncoming
SSPBUF=TX_ADDR
gosub GetIncoming
next
HIGH CSN
pauseus 10
LOW CSN
SSPBUF=RX_ADDR_P0
gosub GetIncoming
next
HIGH CSN
return
CheckIRQLED:
if IRQ =0 then
low LED1
else
high LED1
endif
SendTXPayload:
high led
low CSN
pauseus 10
SSPBUF=W_TX_Payload
Gosub GetIncoming
for i = 0 to 4
SSPBUF=SendData
Gosub GetIncoming
next
high CE
pauseus 20
low CE
pauseus 20
high CSN
low led
return
ReadRXPayload:
low CE
low CSN
SSPBUF=R_RX_Payload
Gosub GetIncoming
for i = 0 to 4
SSPBUF=NOP
Gosub GetIncoming
RecData=Temp
next
high CSN
RX_DR=1
ThisReg=REG_STATUS
gosub SetGetReg
high CE
return
SetUPMirfV2:
REG_SETUP_AW=5
gosub SetGetReg
RX_ADDR_P0=TX_ADDR
ENAA_P0=1
ThisCmd=W_REG_EN_AA
ThisReg=REG_EN_AA
gosub SetGetReg
ERX_P0=1
gosub SetGetReg
gosub SetGetReg
RF_CH=40
ThisCmd=W_REG_RF_CH
ThisReg=RF_CH
gosub SetGetReg
gosub SetGetReg
PWR_UP=1
CRC0=1
EN_CRC=1
ThisReg=REG_CONFIG
gosub SetGetReg
pause 2
return
