- Fri Mar 21, 2008 2:09 pm
#45144
it seems to be a signal problem. When the connection try 6
times it give ups and then you can try to connect manually. So at this
momment the antenna signal seems to be stable at 8,0 or 7,0, enough to
connect. Then i try AT+cops=1,2,74810 manually and the antenna signal
drops down (99,99). Then when it gives up again the antenna get stable
again. I postu a txt of the console with the modem.
at+csq
+CSQ: 7,0 (*** AT+creg=0,3 .. not trying to connect)
OK
at+csq
+CSQ: 8,0 (*** AT+creg=0,3 .. not trying to connect)
OK
at+csq
OK
at+csq
OK
at+csq
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 9,0
OK(*** AT+creg=0,3 .. not trying to connect)
at+csq
+CSQ: 9,0
OK
at+csq
+CSQ: 9,0
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 7,0
OK
at+csq
+CSQ: 7,0
OK
at+csq
+CSQ: 7,0
OK
at+csq
+CSQ: 7,0
OK
at+csq
+CSQ: 7,0
OK
at+csq
+CSQ: 7,0
OK
at+csq
+CSQ: 7,0
at+cops=1,2,74810
OK
at+csq
+CSQ: 7,1 (*** AT+creg=0,2 .. trying to connect)
OK
at+csq
OK
at+csq
OK
at+csq
+CSQ: 99,99 (*** AT+creg=0,2 .. trying to connect)
OK
at+csq
OK
at+csq
OK
at+csq
OK
at+csq
+CSQ: 7,1 (*** AT+creg=0,3 .. not trying to connect)
OK
at+csq
OK
at+csq
OK
at+csq
+CSQ: 9,0 (*** AT+creg=0,3 .. not trying to connect)
OK
at+creg
+CREG: 0,3
OK
at+cops=1,2,74810
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 99,99 (*** AT+creg=0,2 .. trying to connect again)
OK
at+csq
+CSQ: 8,0
OK
at+csq
+CSQ: 8,0
OK
at+creg
+CREG: 0,3
