Ok, I'm getting scary good at taking o-scope screen shots.
But first, if you want to see an overview of the breadboard:
http://flash.360vl.com/~lcox/breadboard ... oardRF.jpg. The Arduino mini-stamp in the upper part is separate. The only thing it's doing for me at the moment is giving me +5v from the USB connection. I plan to hook it up eventually to this experiment, but right now, the focus is on the middle (TX) and bottom right (RX). Notice my transmitter antenna strapped to the BBoard on the left. That's the 434 antenna I was referring to earlier that I got from Renton.
I did several of the suggested experiments. Here are the results.
I put a diode between VCC and pin one of the decoder to pull down the supply voltage as suggested by riden. Unfortunately it didn't help - in fact, instead of getting a consistent blip on the RX LED, sometimes it wouldn't light...it was a lot more inconsistent/ hit and miss.
I measured the voltage at pin one and got 4.75v so it didn't drop quite as much as might be expected. The Vin without the diode is about 5.05-5.10v, so didn't get the .6v-.7v voltage drop with the diode experiment and the results were unstable.
So, I replaced the diode with a straight jumper to vcc. Then found a 10k resistor and went from vcc to the data in pin of the decoder to try to pull that up. First, I did an o-scope shot of the data-in pin without the pull-up and got a nice wave on this shot:
http://flash.360vl.com/~lcox/breadboard ... Pullup.jpg The bottom of the wave is my 0v reference point just so you know. So, it's amplitude looks like it's around 3.75v.
With the 10k pullup, here's the o-scope shot:
http://flash.360vl.com/~lcox/breadboard ... Pullup.jpg You can see the pull-up did its job. The top amplitude of the wave is about 4.5v so should be right in the sweet spot, I think.
The results are maddeningly consistent. I just get a quick blip on the output side of the decoder with the pull-up.
I then tried running with both the diode on pin one of the decoder and the pullup on data in. Same results, though interestingly, it seemed a little more spurious. With the photointerrupter constantly blocked (high), occasionally I'd get some flicker out of the RX LED that seemed like noise except that without the diode and pullup, I never saw any flicker...half wondering if it was thinking about working, but wasn't quite there.
I appreciate all the ideas to check out. It's got to be close, but I don't know what's missing. Any other ideas to try?
