pic32mx795/512H bootloader
KamPutty
Post by KamPutty » Wed May 28, 2014 1:34 pm
Hi all,
I just want to ask specific questions with hopefully a yes no answer to make sure I understand before implementing a bootloader.
I'm using a pic32mx795H512F...
There are 2 modes for the bootloader
- Use the Bootloader memory area (12k)
- Install the Bootloader in the main memory area (512k)
My understanding is that if I install the bootloader in the bootloader area, I cannot use the debugger. Is this a true statement?
If I want to use a debugger in conjunction with the Bootloader, I must install it in the application area. Yes?
I just need a simple UART bootloader; program starts, polls the UART for 't' seconds, then continues if no Bootloader updates etc.
Much appreciated!
~Kam
"Before you criticize someone, you should walk a mile in their shoes.
That way, when you criticize them, you're a mile away and you have their shoes."
