ATmega328p ardiuno bootloader problem
zainuddinkhan
Post by zainuddinkhan » Sun Nov 20, 2011 7:29 am
the board came with the bootloader and it was working with the python interface but then i did an experiment and reprogrammed it with avr pocket programmer the other firmware that also worked. now i wanted to go back to arduino and see the python interface working and it is not goin what to do plz help with proper steps.
thanks
zainuddinkhan
Re: ATmega328p ardiuno bootloader problem
Post by zainuddinkhan » Sun Nov 20, 2011 10:32 am
i have FTDI 3.3v cable and avr pocket programmer plz help me out using these two devices.
Thanks
zainuddinkhan
Post by zainuddinkhan » Sun Nov 20, 2011 10:47 am
i am having the atmega328p on serial 9dof razor imu from sparkfun. the bootloader of this atmega328p is what i want to restore.
RobertD
Post by RobertD » Mon Jun 04, 2012 8:20 am
AVR ISP shield gives error message
Postby RobertD » Sun Jun 03, 2012 9:21 pm
Greetings friends.
I use Arduino Uno latest version with latest programmer, with the AVR-ISP shield I just bought, I setup correctly, uploaded the example software in the Uno, and when I try to burn the 328P chip I get "error while burning bootloader" : avrdude: stk500_getsync(): not in sync: resp=0x00
The chip is inserted correctly, should I connect the cable that came with the AVR to something?
I don't know what I'm doing wrong here.
Thanks for your help.
