Screamer and WDT
DLK
Screamer and WDT
Post by DLK » Wed May 06, 2009 9:23 pm
I have an application that is using most of the program memory on a 16F877A. This application needs the WDT to be enabled. However, when I enable it (using IC-Prog with an ICSP programmer after booting in my image), my code runs fine, but subsequent bootload attempts using Screamer fail after loading a little less than 10% of my boot image, due to the watchdog timing out. Would it be possible to add a CLEARWDT to the Screamer code loop?
Thanks-Dan
