help me pleas,I need a c compiler for this code :
Postby yonas » Wed May 21, 2008 11:34 pm
Hi there,i am doing my final project but i found difficulty on the c compiler .
I need a c compiler for this code so,that i can find the HEX file.
* P R E P R O C E S S O R D I R E C T I V E S *
#include <16F877A.h>
#device *=16 ADC=10 // Use 16-bit pointers, use 10-bit ADC
#use delay(clock=20000000)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
int8 errorCCond;
int8 zeroCond;
int8 oneCond;
int8 twoCond;
int8 threeCond;
int8 fourCond;
int8 fiveCond;
int16 tempVal;
// End Preprocessor Directives
#include "Include\Compiler.h"
#include "Include\Globals.h"
#include "Include\Misc.c"
* F U N C T I O N P R O T O T Y P E S *
void initTimers( void);
void initADC( void);
void timer1ISR( void);
void timer2ISR( void); // ISR does not stand for Illinois Street Residence
* M A I N R O U T I N E *
#pragma zero_ram // Interesting command ....
void main( void)
disable_interrupts(GLOBAL); // We don't want to be interrupted yet
delay_ms(500); // wait for voltages to stablize
Set_Tris_A(MY_TRISA); // Port A's I/O
Set_Tris_B(MY_TRISB); // Port B's I/O
Set_Tris_C(MY_TRISC); // Port C's I/O
delay_ms(50);
initTimers(); // This is where the interrupts are enabled again
delay_ms(50);
initADC();
while(FOREVER)
readADC_1();
// End Main Routine
* S U B - R O U T I N E I M P L E N T A T I O N S *
// Purpose: Initializes timer interrupts
// Precondition: None
// Postcondition: Timers and interrupts are enabled
void initTimers(void)
setup_timer_1( T1_INTERNAL | T1_DIV_BY_8 ); // confusing?
setup_timer_2( T2_DIV_BY_4, 0x20, 2); // even more so!
enable_interrupts(INT_TIMER1);
enable_interrupts(INT_TIMER2);
enable_interrupts(GLOBAL);
timer1Count = 0;
timer2Count = 0;
// Purpose: Initializes ADC
// Postcondition: ADC is configured
void initADC(void)
setup_adc(ADC_CLOCK_INTERNAL);
set_adc_channel( 0 );
delay_us(10);
//End Sub-Routine Implementions
* I N T E R R U P T S E R V I C E R O U T I N E S *
// Purpose: Timer1 ISR
// Precondition: initTimers called
// Postcondition: Timer1 counter updated
#INT_TIMER1
void Timer1ISR(void)
timer1Count++;
timer2Count++;
#INT_TIMER2
void Timer2ISR(void)
if (timer1Count == 0)
if (((ADC_1 * 10) < 1013) || ((ADC_1 * 10) > 2058))
errorCCond = 1;
zeroCond = 0;
oneCond = 0;
twoCond = 0;
threeCond = 0;
fourCond = 0;
fiveCond = 0;
//displayC -> 0
else if (((ADC_1 * 10) > 1013) && ((ADC_1 * 10) < 1218))
tempVal = 1013;
errorCCond = 0;
zeroCond = 1;
oneCond = 0;
twoCond = 0;
threeCond = 0;
fourCond = 0;
fiveCond = 0;
//displayC -> 1
else if (((ADC_1 * 10) > 1218) && ((ADC_1 * 10) < 1423))
tempVal = 1218;
errorCCond = 0;
zeroCond = 0;
oneCond = 1;
twoCond = 0;
threeCond = 0;
fourCond = 0;
fiveCond = 0;
//displayC -> 2
else if (((ADC_1 * 10)> 1423) && ((ADC_1 * 10) < 1628))
tempVal = 1423;
errorCCond = 0;
zeroCond = 0;
oneCond = 0;
twoCond = 1;
threeCond = 0;
fourCond = 0;
fiveCond = 0;
//displayC -> 3
else if (((ADC_1 * 10) > 1628) && ((ADC_1 * 10) < 1832))
tempVal = 1628;
errorCCond = 0;
zeroCond = 0;
oneCond = 0;
twoCond = 0;
threeCond = 1;
fourCond = 0;
fiveCond = 0;
//displayC -> 4
else if (((ADC_1 * 10) > 1832) && ((ADC_1 * 10) < 2037))
tempVal = 1832;
errorCCond = 0;
zeroCond = 0;
oneCond = 0;
twoCond = 0;
threeCond = 0;
fourCond = 1;
fiveCond = 0;
//displayC -> 5
else if (((ADC_1 * 10) > 2037) && ((ADC_1 * 10) < 2058))
errorCCond = 0;
zeroCond = 0;
oneCond = 0;
twoCond = 0;
threeCond = 0;
fourCond = 0;
fiveCond = 1;
else if ((timer1Count > 0) && (timer1Count < 230)) //display the output of pin D
//displayC -> EE
if (errorCCond == 1)
output_high (PIN_B0);
output_low (PIN_B1);
output_low (PIN_B2);
output_high (PIN_B3);
output_high (PIN_B4);
output_high (PIN_B5);
output_high (PIN_B6);
//displayC -> 0
else if (zeroCond == 1)
output_high (PIN_B1);
output_high (PIN_B2);
output_low (PIN_B6);
//displayC -> 1
else if (oneCond == 1)
output_low (PIN_B0);
output_low (PIN_B3);
output_low (PIN_B4);
output_low (PIN_B5);
//displayC -> 2
else if (twoCond == 1)
//displayC -> 3
else if (threeCond == 1)
//displayC -> 4
else if (fourCond == 1)
//displayC -> 5
else if (fiveCond == 1)
else if (timer1Count == 230)
timer1Count = 0;
//enable_interrupts(GLOBAL);
if (timer2Count == 0)
errorCCond = 1;
zeroCond = 0;
oneCond = 0;
twoCond = 0;
threeCond = 0;
fourCond = 0;
fiveCond = 0;
//displayC -> 0
tempVal = 1013;
errorCCond = 0;
zeroCond = 1;
oneCond = 0;
twoCond = 0;
threeCond = 0;
fourCond = 0;
fiveCond = 0;
//displayC -> 1
tempVal = 1218;
errorCCond = 0;
zeroCond = 0;
oneCond = 1;
twoCond = 0;
threeCond = 0;
fourCond = 0;
fiveCond = 0;
//displayC -> 2
tempVal = 1423;
errorCCond = 0;
zeroCond = 0;
oneCond = 0;
twoCond = 1;
threeCond = 0;
fourCond = 0;
fiveCond = 0;
//displayC -> 3
tempVal = 1628;
errorCCond = 0;
zeroCond = 0;
oneCond = 0;
twoCond = 0;
threeCond = 1;
fourCond = 0;
fiveCond = 0;
//displayC -> 4
tempVal = 1832;
errorCCond = 0;
zeroCond = 0;
oneCond = 0;
twoCond = 0;
threeCond = 0;
fourCond = 1;
fiveCond = 0;
//displayC -> 5
errorCCond = 0;
zeroCond = 0;
oneCond = 0;
twoCond = 0;
threeCond = 0;
fourCond = 0;
fiveCond = 1;
else if ((timer2Count > 0) && (timer2Count < 230))
output_high (PIN_C0);
output_low (PIN_C1);
output_low (PIN_C2);
output_high (PIN_C3);
output_high (PIN_C4);
output_high (PIN_C5);
output_high (PIN_C6);
output_high (PIN_C1);
output_high (PIN_C2);
output_low (PIN_C6);
else if (fiveCond != 1)
if (((ADC_1 * 10) - tempVal) < 20)// displayD -> 0
else if ((((ADC_1 * 10) - tempVal) > 20) && (((ADC_1 * 10) - tempVal) < 40))//displayD -> 1
output_low (PIN_C0);
output_low (PIN_C3);
output_low (PIN_C4);
output_low (PIN_C5);
else if ((((ADC_1 * 10) - tempVal) > 40) && (((ADC_1 * 10) - tempVal) < 61))//displayD -> 2
else if ((((ADC_1 * 10) - tempVal) > 61) && (((ADC_1 * 10) - tempVal) < 81)) //display ->3
else if ((((ADC_1 * 10) - tempVal) > 81) && (((ADC_1 * 10) - tempVal) < 102))//display ->4
else if ((((ADC_1 * 10) - tempVal) > 102) && (((ADC_1 * 10) - tempVal) < 122))//display ->5
else if ((((ADC_1 * 10) - tempVal) > 122) && (((ADC_1 * 10) - tempVal) < 143))//display ->6
else if ((((ADC_1 * 10) - tempVal) > 143) && (((ADC_1 * 10) - tempVal) < 163))//display ->7
else if ((((ADC_1 * 10) - tempVal) > 163) && (((ADC_1 * 10) - tempVal) < 184))//display ->8
else if ((((ADC_1 * 10) - tempVal) > 184) && (((ADC_1 * 10) - tempVal) < 204))//display ->9
else if (timer2Count == 230)
timer2Count = 0;
yonas
Postby polly » Tue Jun 03, 2008 11:04 am
Maybe this guy can help:
Power Monitoring Project
By
Kevin Repple
ECE 445, SENIOR DESIGN PROJECT
SPRING 2006
TA: Ishaan Gupta
Date: 05/01/2006
polly
Postby silic0re » Tue Jun 03, 2008 12:30 pm
That's really funny and terrible at the same time...
Are you the TA, or the student who wrote it in the first place?
silic0re
Postby Philba » Tue Jun 03, 2008 12:41 pm
I'd say it doesn't really matter - busted!
It is a real shame that people feel like they can just rip off someones code and turn it in as their own. I sure hope the guy who designs AEDs or air traffic controller systems or other life-safety equipment didn't cheat his way through school.
As long as we are at it, that is pretty hideous code. I think it could be collapsed into about 1/10 the number of lines.
Philba
Postby Polux rsv » Wed Jun 04, 2008 1:53 am
I hope the guy who wrote this code is not a programming student :lol:
Angelo
Polux rsv
Postby spikegomez » Fri Dec 19, 2008 11:57 pm
Yeah hope so....
_________________
A cool idea from Busby SEO Test
spikegomez
Postby old_dave » Thu Jan 08, 2009 2:17 am
The compiler for that code looks to be CCS and can be found at www.ccsinfo.com
old_dave
Postby kevinrepple » Sat Jul 18, 2009 5:09 pm
Polux rsv wrote:I hope the guy who wrote this code is not a programming student :lol:
Angelo
He's not.
kevinrepple
Return to Boot Loading
Who is online
cron
