Questions &/or issues related to products in the Audio category should be posted in this forum.
#207225
Hi Sparkfun team, maybe you can help with this.
I'm using the Super WAV trigger as an 8ch playback device for a sound installation. However, compared to playing out of my audio interface (with the exact same sound files and no EQ/processing whatsoever) I am getting significantly less low end from the WAV trigger.
I am using the Mono firmware and a single trigger to start & loop all 8 files going to individual ins on an amp (same amp & speakers used with the computer interface).
-- Is there some EQ or Filter setting I might have missed?
I am powering the superWAV trigger from a USB. - let me know if you need any more info!
Thanks,
#207283
Hello gdujat.
I'm not aware of a configurable filter or EQ in theTsunami firmware.
The schematic shows a high pass filter on the audio output hardware that should be passing everything above 1.6Hz so anything audible should be getting through. You might try boosting the volume a bit to see if that brings the low end up.
