Everything ARM and LPC
By JJ
#198338
Anyone know what to do with the KEY signal on a 10 pin connector? I've seen suggestions it can just be grounded, but I'm concerned this might short out a programmer. (I use a Flyswatter 2 with OpenOCD)
In the past I've used 20 and 14 pin JTAG but would like to reduce it to 10 to save board space (without going Tag-Connect) and fall in line with current recommendations.
This is for an LPC4078. Three options I can think of:
* Leave it floating
* Ground it
* Connect it to P2.10, the ISP enable pin (which currently has a weak 100k pullup on my board since I don't ever use the boot ROM).
I have a vague suspicion it's really intended for the third option... but if NOT and I connect it there it could make the board get stuck in the ISP on boot.
I can't seem to find ANY documentation discussing this...
Anyone know?
Will OpenOCD ever use it?
Is it electrically connected when adapted to a 20 pin programmer like the Flyswatter 2?
By JJ
#198339
Also, I'm concerned if it's an ISP enable it would be held high unless trying to enter ISP. If I ground it this would not be so great and might cause the programmer to shutdown on overload if it shorts (FT2232R I believe is what the FS2 uses, not sure if it's buffered).
By JJ
#198340
Looking at the schematic for the Olimex 20-to-10 adapter, they run this through an unpopulated resistor, so I guess I can just ground it. (That's the adapter I use.)
What about GNDDetect? Another pin to just ground?
