Logomatic Low freq?
Posted: Sun Jan 03, 2016 8:25 am
Is there an expert could explain and let me know the exact settings I should apply to monitor at low frequency (in the range of 1 measurement/per hour) with the logomatic (data logger)?
If I understood correctly with T0MR0, which is a 32 bit variable, I can set to the maximum of 2^32 = 4294967296 -> 4294967296 / 58982400 = 72 s.
Is there a way to get a slower frequency rate?
As I'm a novice, I would appreciate if you could let me know how the exact changes I have to do in the code of the main.c file?
Many thanks for your help.
Christoph
Christoph
