Everything ARM and LPC
By GLinBoy
#163231
I'm studying Using Open Source Tools for AT91SAM7S Cross Development, and then looking for tool that is named on this article; But unfortunately, I can't find this tools:
  • yagarto-ide-20061002-setup.exe
  • yagarto-bu-2.17_gcc-4.1.1-c-c++_nl-1.14.0_gi-6.5.5.exe
After all, i see that official site said: "Task completed" :doh: ! I need that tools to setup first development environment and then upgrade to new version, Step By Step, because i new in ARM development and this article is one of best that i found. If possible for you, help me to download right this application.
Kind regards,
Hojjat Abedie -=- GLinBoy
By GLinBoy
#163514
Hello again,
After searching, I try connect to people that can help me to find this file.
After all, I use " Make a wish " of Olimex, and then they answer me; They give me this link that continent all of file that i need:
https://docs.google.com/file/d/0B7WHuNC ... sp=sharing
It is packed with Nero software. You might write the image to a CD and then explore it or you can use virtual CD software to explore it directly from your hard disk (like “Alchohol120%” or “Daemon Tools”).
Also they say a recommend:
I also recommend you to check the newer revision of our “Open Development Suite” here: https://www.olimex.com/Products/ARM/JTA ... s/OpenOCD/
Contents of this CD include:
Z:\DOCs
Z:\HOW_TO_INSTALL.txt
Z:\OTHERS
Z:\Olimex-GCCFD-240907.exe
Z:\revision.txt
Z:\DOCs\ARM Cross Development with Eclipse version 4.pdf
Z:\DOCs\ARM-USB-OCD.pdf
Z:\DOCs\Spanish Tutorial ARM rev2.pdf
Z:\OTHERS\anglia
Z:\OTHERS\yagarto
Z:\OTHERS\anglia\GettingStarted.pdf
Z:\OTHERS\anglia\IDEaliST-update.exe
Z:\OTHERS\anglia\IDEaliST.exe
Z:\OTHERS\anglia\sarm.exe
Z:\OTHERS\yagarto\openocd-2007re204-setup-rc01.exe
Z:\OTHERS\yagarto\yagarto-bu-2.17_gcc-4.2.1-c-c++_nl-1.15.0_gi-6.6_20070901.exe
Z:\OTHERS\yagarto\yagarto-ide-20061002-setup.exe
special Thanks from Olimex :text-thankyouyellow:
