- Tue Dec 11, 2012 11:17 pm
#153106
Hi, I am fairly new to electronics so I need some help to set up my circuits.
I am trying to use this (http://www.usdigital.com/products/encod ... MgeWoNX0Wc) absolute shaft encoder fro US Digital with the Galago microprocessor (http://www.kickstarter.com/projects/kuy ... ngs-better).
I don't really understand how PWM works and which pins I am allowed to use on the galago to get input from the encoder. Dumb question: Can I use a 10 bit device on a 16 or 32 bit i/o? Also the encoder is going to be powered with 5V while the galago operates on 3.3V. I looked at the Cortex-M3 tolerances and it looks like it is 5V tolerant on the input, just can't produce 5V output. This leads me to believe that I can read values from the encoder without having to use a logic level converter.
Any suggestions/Lessons I can look at?
All help will be appreciated
Thanks!
Thanks!
