- Fri Feb 17, 2006 1:04 am
#9991
I have just received the LPC2148 board and I am having trouble attaching to the board through JTAG.
I am using a professional JTAG device that my work uses called Trace32 by Lauterbach. http://www.lauterbach.com/
I have the device setup in such a way that I can verify the scan chain is working correctly (requires turning off EnReset and TRST)
The problem is, I cannot bring the system up. The command is SYSTEM.UP, and it always generates an error (and I think the processor is resetting).
What *should* happen when I issue this command, is simply the Trace32 (JTAG) software should connect, and I can then read values from memory, or write to flash and so on.
I have tried a JTAGCLOCK as slow as 100kHz, and I have also tried RTCK. Both let me verify the scan chain is correct, but will not let me bring the system up.
So, I am stuck. Can anyone give me any pointers? Does the LPC2148 board need some more jumpers set or switches turned on/off? I haven't actually found any documentation to explain what the switches do yet.
Anyway, any suggetions will be appreciated.
Thanks,
AH
Thanks,
AH
