Steffen595 wrote:yepp, may as well try. So if I get it to work, I have one to spare. Suppose only Farnell to get the 2148 in Australia, AUD 25.
Ug, Farnell.
I find their prices so inflated here in Europe that I order from Digikey and even with the 19.6% tax at the border I end up way ahead. Maybe they're a bit better in Australia, but I honestly don't think I've ever ordered from them here (probably 25-30 Digikey orders last year, and maybe 4-5 from Mouser when Digikey didn't work out).
Honestly, I wouldn't bother ordering a new LPC2148 if you've already ordered a new board since you don't know what's dead and it's likely just a waste of money. But have fun trying to soldering and desoldering the chips. Discretes cost nothing and are easy to practice with ... QFPs are what takes a bit of practice to get used to (though it's not complicated).
Try getting some of the resistors off, for example, and then solder them back on. Should be an easy and harmless way to built some confidence soldering SMT stuff. If you want to make it a lot easier, I'd order a flux pen. Makes getting the solder to reflow MUCH easier. Kester 2331-zx is my personal favourite (I think Sparkfun even sells those?), but anything should be fine. You just put a bit of flux on the joints before trying to get the solder to 'reflow' again.
Here's a video I made where you can see some flux applied and a solder bridge removed (though I was being lazy and should have cleaned the tip between every pad ... the last one didn't want to co-operate because there was already some solder on the tip. The smoke is cause by the flux, though ... it would be much harder to work without it.
http://www.youtube.com/watch?v=-T3DdG_7jAM
PS: Ironically, I think that's even an LPC2148 in the video.
