kdoney wrote:I'm sure you're right about the power of the ARM but just for kicks, give me an example of a project which would be difficult to impliment on any other controller. Oh, and I don't mean because the peripherals aren't readily available.
Anything with large processing requirements. Image processing, or graphical library processing UI, IP Stack, RF Mesh.... It's impossible to say specific instances as everything can be done on regular 8bits to a degree and there's a gray area of super optimization. I'm not certain why your discounting the peripherals either, since most ARM7 variants strengths are their wide peripheral ranges. You can also step up to ARM9 or sideways to ARM Cortex-M3 with the same development environment.
Really, if you didn't think an ARM7 was any more useful than say a standard 8bit, it makes your decision to start with one even more confusing.
If you decide to try ARM7 sometime again in the future, I would suggest trying out an LPC devel board. Keep the JTAG Tiny as long as there is nothing physically wrong with it, as it is it should work fine. The LPC yahoogroup mailing list is very active and you can get a lot of help from there with startup issues.
