LPC2478-STK and Flash Magic(resolved)
Posted: Mon Aug 03, 2009 4:35 am
by mrick0363
i just receive a LPC2478-STK evaluation board from OLIMEX and i would like to flash U-BOOT on it with Flash Magic (for testing flashing procedure) but i can't because i always have "Failed to autobaud - step 1". I have configure ,
Step 1 as :
Device : LPC2478
COM Port : COM 1 (real com port from PC, not FTDI)
Baud rate : 9600
Interface : None (ISP)
Oscillator (MHz) : 12
Step 2 as :
tick "Erase all Flash+Code Rd Prot"
Step 3 Hex File from correct location
Step 4 : None tick
I can't go to flash magic forum because of my enterprise internet restriction (it sucks !, sorry).
Then can anyone help me to find correct procedure ?
Thanks a lot
PS : In normal operation ,the board boot correctly ,i see penguin on LCD and text on PC COM1 terminal , i can entering into UBOOT menu or let uclinux boot on USB mass storage
Posted: Tue Aug 04, 2009 11:44 pm
by mrick0363
finally it simply the null modem cable which was defect (Pin6 connect to Pin8).Now it's ok.
Posted: Wed Aug 05, 2009 2:42 am
by king_8210
So...your problem was that the null modem cable was defect ?
And then you changed another one , now it's ok ?
I have the same problem with you .
But I can't find the solution .
You can say it more detailed ?
Thank you for grateful .
Posted: Wed Aug 05, 2009 1:30 pm
by mrick0363
Hello
Yes it was the null modem cable , here you will find info (Supraman answer) for check it:
viewtopic.php?p=56369&sid=0a2d69e99a49a ... 3927ca7902.
