Everything ARM and LPC
By agreer
#58044
I haven't been having much luck getting the Olimex GCCFD environment working. I was just wondering if, in general, people are having much luck using opensource development tools with the Cortex-M3 processors? As far as I know, codesourcery is the only outfit to claim that their free tools will support thumb2 compilation. What I'd really love is to find a build of an arm-elf-xxx toolset (including insight!) that supports CM3. After wasting so many hours trying to make an opensource environment work, I'm seriously considering paying the cash to get CrossWorks.
By SodaAnt
#58058
I can't answer your specific question, but just wanted to say that I'm a CrossWorks user and it's excellent. I use it with an ST eval board and it is well worth $150 if you're a non-commercial user like I am.
By BusError
#58062
I use the CodeSourcery toolchain, and use Eclipse 'naked' over it for editing and building (makefiles).
Gcc is pretty good for code generation, and you can debug-ish with openocd.
So it's possible to use a full opensource free toolchain...
I'm targeting Stellarises...
By agreer
#58074
theatrus wrote:
agreer wrote:
theatrus wrote:You need to either use CodeSourcery, or gcc 4.3.x to get Cortex-m3 support.
Take a look at this page for instructions:
http://elua.berlios.de/tut_gcc_cortex.html
Do you suppose I could get that tutorial to work if I performed the compilation on a Vindows machine under Cygwin?
Yes, it should work just fine.
I might still try that, but I think my first attempt will be from inside an Ubuntu virtual machine.
By static
#58167
yes, latest codesourcery binaries (you don't have to build everything) work good for stm32 under cygwin as well as under ubuntu.
examples of environment/makefiles/project can be found by looking for name 'lanchon' (who has kindly shared his gcc based examples with community)
