- Tue May 24, 2005 10:22 am
#5223
I am trying to use the drivers for the external MXIC MX26LV800B flash. I am using Keil and so I am attempting to port the code provided by Olimex, this code was written for IAR tools.
To start I am attempting to read the device id, so far I hav had no luck, I read back 0xFFFF. I have written a flash.id file which sets:
BCFG0 = 0x1000FBEF; // BCFG0 Flash Bus Configuration
PINSEL2 = 0x0F6001E4; // CS0, OE, WE,
// D0..31, A1..23, JTAG
The command and read_id functions:
int command(unsigned char command, unsigned short *address)
*address = (unsigned short)command;
return PASS;
int FlashID(unsigned short* address)
unsigned int hold;
// Put device into 'READ_ID'.
command(KEY_AA,(unsigned short*)(FIRST_KEY_ADD+FLASH_BEGIN));
command(KEY_55,(unsigned short*)(SECOND_KEY_ADD+FLASH_BEGIN));
command(READ_ID,(unsigned short*)(THIRD_KEY_ADD+FLASH_BEGIN));
hold = *address; // Read Data
command (RESET_DEV, address); // Reset 26LVXXXX
command (READ_ARRAY, address); // C3 Put device back into read mode.
// Return Item
return(hold);
Thanks
Rich
return PASS;
unsigned int hold;
// Return Item
return(hold);
Thanks
Rich
