Questions &/or issues related to products in the Power category should be posted in this forum.
By ChiefGeek63
#208328
One thing I have always wanted is to replace the Redboard barrel power connecter with terminal blocks.
I've used the barrel power connector to terminal device (PRT-10287), but it's too large and looks like crap. Additionally with this device it seems easier for the device to fall out due to vibration.
I want the solid connection of a terminal block.
Does anybody know of a connecter where I can desolder the Redboard barrel power connector and replace it with something that has the same footprint but with terminal blocks?
Thanks...John
By TS-Chris
#208475
Hi John.
Unfortunately I'm not aware of a terminal block that would have the same footprint as the barrel jack connector on the RedBoard. What I'd recommend if you don't want to plug in a barrel jack to the board would be to solder a short pigtail to the positive and negative pads on the existing barrel jack and then connect your terminal block to those wires.
The picture below shows which pads to use.
A connection like this might work for you.
