- Fri Aug 25, 2006 11:04 pm
#17937
Hey everyone,
I haven't had a lot of time lately, but one of my random interests that I run across every so often is optical rangefinders.
Short distance measurement can be done with ultrasonics, Sharp distance sensors (it's an off-axis PSD based system) or an off-axis laser-camera set (same as the Sharp, but using a CCD).
I've recently become interested in what I consider medium distance (around 100m) measurement. While a run-of-the-mill $150 Bushnell laser rangefinder would work just fine, I want to integrate this into my module plans. So, I'm researching the mechanics to build the lowest cost system possible.
Some background first...
There are two main different types of laser rangefinders.
One is the time-of-flight rangefinder, which uses a pulsed laser (Q-switched diode laser or a flashlamp pumped Ebrium rod) to fire off a massive IR pulse and time it, either via an integrating current ADC or via a fast digital comparator and timing circuit. We're looking at 6.6ns per meter, so one meter resolution requires a 150MHz counter. Start and stop need to be done via optical circuitry (so you know EXACTLY when it fires vs timing from a trigger pulse). The other issue is that you need a low pulse length. One calculation I ran across in research papers is that for a 75m return from any object, you'll need something around 40w of power in a 7ns pulse.
More conceptually complex but probably cheaper is the phase modulation rangefinder. This one takes an amplitude modulated light source (laser or otherwise), and uses two identical recieve paths, one that reads from the source and one that reads from the return. These signals (normalized) are mixed together and the resulting pulse width provides a distance measure. By varying the frequency, this method allows accurate measurement at a distance, although it takes up to a second to acquire.
A variation on the PM rangefinder is one that directly couples the laser to the inverse signal from the reciever. This one sets up an oscillating loop that the distance can be measured from. This may be the simplest of all.
Now, I'm leaning towards the PM rangefinder. It has the advantage of hopefully lower cost components and lower power and weight (higher average power so I don't need a 40W pulse!).
Biggest hurdle I've encountered? Price of components. Short range and "local" recievers can run on a PIN photodiode, but every design I've seen for the remote reciever uses an APD photodiode (300x gain vs PIN). PIN diodes are about $10. APDs start at $130 on Digikey. I'd like to make this IR not Red laser based, although red may be part of my initial prototype. I need to investigate the wavelength of IR lasers in CD-RW heads since they're common, and may be fairly powerful if I'm lucky.
Has anyone else been interested in this? Or at least knows if $130 is fairly normal for the bottom end of the APD's?
I also got my hands on an old TI optoelectronics book with a fully analog LED based rangefinder for up to 15 meters (again, uses an APD). I'll have to see about getting the schematics scanned.
Technical Alchemy
